Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-18-2008, 06:43 PM
CAG360 CAG360 is offline
Adding/Programming Remote Transmitter to 94 Explorer
I just got a 2nd remote for it and i don't know how to program it. If someone could give me some instructions on doing it i would be very happy. Thanks
Old 08-18-2008, 07:59 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Adding/Programming Remote Transmitter to 94 Explorer
Welcome to the forum!
As a new member, you need to acquaint yourself with the "Search this forum" feature. I used it to search for the keywords "program remote" and got 35 hits. At least one of those contains directions for programming remotes to a 1994 Explorer.
Also, if you have an owner's manual, the directions are probably in there as well.
-Rod
Old 08-18-2008, 10:05 PM
ok, thanks, i looked in the manual and its not there
Old 08-19-2008, 10:56 PM
i couldnt find anything about a 94 explorer, can anyone help me?
Old 08-20-2008, 06:25 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Section 01-14B: Door Lock Control System, Electronic 1994 Aerostar/Ranger/Explorer Workshop Manual
DESCRIPTION AND OPERATION
________________________________________
NOTE: The remote entry receiver module erases all previous transmitters from memory when the transmitters are programmed or re-programmed. The remote entry receiver module can store up to four transmitters in memory.
To program (or re-program) transmitter(s) into the remote entry receiver module, perform the following steps:
1. Turn ignition switch to ON or ON/ACCESSORY position and momentarily short the two terminals of the Program Connector (J4) (a two-pin connector taped to the wire assembly and accessed by removing the LH quarter access panel). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitter. All doors should lock then unlock to verify the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter).
3. Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
4. Turn ignition switch off. All doors should lock then unlock.
5. Check operation.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
