Old 08-18-2008, 06:26 PM
highvan's Avatar
highvan highvan is offline
Send a message via Yahoo to highvan
Question Leaking coolent
Ok, i have a 96 cavalier 5 speed, with around 150,000 miles on it, nothing great, but it gets me to work and back... A few days ago i noticed my car was leaking anti-freeze, so i figured it must be a hose or maybe a small hole in the radiator, but after looking at it, it's neither. It seems to be a slow drip, but usually by morning, the low coolent light will be on when i start the car and by the end of the day, the car is heating up. I jacked up the front passenger side of the car and it seems to be coming from that side up around where the oil pan is, but its in a spot i can't really see. Like inbetween that piece of plastic they have there and where the belt runs... Does anyone know what the problem is or might be? And i could go about fixing it? Thanks
Some of the stuff I do
www.warrencountyimports.com
Old 08-18-2008, 07:50 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Leaking coolent
Is it coming from the water pump? They have a weep hole in them to let you know when they are failing.
try and get a picture if you can.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 08-27-2008, 08:12 PM
mcalkins3 mcalkins3 is offline
Send a message via AIM to mcalkins3
Re: Leaking coolent
Also keep an eye on the normal headgasket faliure spot, on the RH corner of the head of cylinder #4
Old 08-28-2008, 06:48 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Leaking coolent
yep, that is exactly what happened to me.
i went through hell and back trying to trace that leak, even replaced the coolant resevior
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 08-28-2008, 01:56 PM
wafrederick wafrederick is offline
Banned
Re: Leaking coolent
I agree with the headgasket too,checking that area.Put a pressure pump on and that is one way of finding the leak also.If it is the headgasket,replace it instead of patching it up with something
Old 09-01-2008, 04:20 PM
highvan's Avatar
Re: Leaking coolent
well, I changed the thermostat and the water pump, it;s still overheating... I did notice that the one hose that comes off the radiator closest to the battery, that hooks into the top right hand side of the motor seems like it's about to burst, like it's not letting the water pass through
Old 09-01-2008, 04:21 PM
highvan's Avatar
Re: Leaking coolent
also, if i take the thermostat out, it seems to be fine, other then the fact that i don't have heat from my heater
Old 09-01-2008, 08:17 PM
Re: Leaking coolent
then that would lead me to believe your new thermostat is bad, which is very common
Old 09-01-2008, 09:37 PM
highvan's Avatar
Re: Leaking coolent
Even though i changed it with a new one? Is there a chance the new one is bad too?
Old 09-01-2008, 10:39 PM
Re: Leaking coolent
yes, that is very common
Old 09-04-2008, 04:43 PM
highvan's Avatar
Re: Leaking coolent
Well, Ive tried 3 different thermostats and still the same thing. It overheats with it in and the radiator hose on the right beside the battery gets real tight, like it's blocked and is about to burst.... I take the thermostat out and its fine
Old 09-04-2008, 05:37 PM
Re: Leaking coolent
are you buying crappy $7-8 thermostats from autozone or somewhere else or are you buying quality $20-30 ones?
if it works fine without a thermostat that still leads me to believe the thermostat is the problem
Old 09-20-2008, 12:59 PM
highvan's Avatar
Re: Leaking coolent
after buying 3 different 8 dollar autozone thermostats, i went and paid 27 for one at a dealer... and YUP still does it.... I'll drive for about 5 min and it's in the red and boiling... The one hose by the battery that connects to the top of the motor, is always about to burst once it gets hot. SO there must be something else stopping the flow.. any more ideas?
Old 09-20-2008, 05:55 PM
Jason/RKBA's Avatar
Jason/RKBA Jason/RKBA is offline
Re: Leaking coolent
I'm not sure if it is possible but are you installing it backwards?
Old 09-21-2008, 09:31 AM
highvan's Avatar
Re: Leaking coolent
No, it will only fit one way...
