trac off/ trac active and abs module problem
i have 2001 town car . i had replaced my abs module and i got it from junkyard but still abs and brake light comes on.sometimes when im driving traction active light will start blinking and car will loose power. if i put trac off switch on then it will run fine. trac active would come and go away . it wont come on when i m driving on high speed. i got it checked on computer and it says abs module is bad. anybody had any ideas or suggestions . pls help.
Re: trac off/ trac active and abs module problem
I know basically nothing about ABS except, my '95 TC has a module for each wheel. To find where the problem is you must pay Ford many $$$$$$$ just to check it with their tool and then many more $$$$$ to fix it.
Sorry, but that has been my personal experience. If someone knows a better way I'd like to know it because there are three more modules- on my car.
Stan'98 Lincoln Towncar - white 100k '08 Mercury Grand Marquis - maroon 30k '98 Dodge 3/4 ton, Cummins Diesel, 4 x 4, 4 door, extended cab, long bed. 140k |
guys i have noticed one more thing regarding trac active / trac off , trac active light always comes at the speed of 38/39 miles. if i drive less or more than 39 it wont come on . im guessing it could be speed sensors too. any ideas plz help
Try the speed sensor. Interesting that it comes on at 38-39mph, the same speed that the overdrive kicks in. Is your speedometer displaying correctly? I had to change my speed sensor on my '96. It was extremely easy and cheap. Fixed speedometer, overdrive and rpm a little.
[quote=jeffbazell]Try the speed sensor. Interesting that it comes on at 38-39mph, the same speed that the overdrive kicks in. Is your speedometer displaying correctly? I had to change my speed sensor on my '96. It was extremely easy and cheap. Fixed speedometer, overdrive and rpm a little.
