Old 08-18-2008, 03:38 PM
wildman56 wildman56 is offline
ignition switch
i have a 1988 chevy s10 and when i try to shut my key off, it wont turn all the wayback to take the key out. i sprayed wd40 in it and it worked for a day .then today it did it again .can anyone help i dont want to keep unhooking the battery on and off . it is a 5 speed
Old 08-19-2008, 04:55 PM
dragon_kin01 dragon_kin01 is offline
Send a message via Yahoo to dragon_kin01
Re: ignition switch
Sounds like you need a new ignition switch. Its not as intimidating as it sounds. I have an 85 s10 5 spd and its really simple. mark and remove the steering wheel. remove the clock spring and the phillips head screw that holds the switch into place. slide it out and reinstall in reverse order. when u put your steering wheel back on make sure its in the same position as when u took it off or your alignment will never be on again. thats why u mark before u remove
FORD - Found On Road Dead, ****ed Over Rebuilt Dodge, Flip Over to Read Directions, Fix Or Repair Daily,(backwards) Driver Returns On Foot (it shows I hate ford)
