Old 08-18-2008, 10:05 AM
cody84 cody84 is offline
what is the part called?
i have a 92 taurus with a 3.8 i just recently replaced the water pump and now its leaks not out of the water pump but there is a metal tube that runs from the water pump to the lower radiatior hose there is also a little hole for a bolt to go through....does anyone know what its called so i can go to a parts store and get a new one?
Old 08-18-2008, 10:15 AM
Scrapper Scrapper is offline
AF Premium User
Re: what is the part called?
the tube your talking about you can go to parts store and have them pull water pump up and show you what part you need. i think your talking about the plug thats in it or to you mean the tube?
Old 08-18-2008, 10:18 AM
its the metal tube that goes on the inside of the water pump and there is a rubber o ring to keep the tube snug in the water pump and the other end goes the the lower radiator hose...thats the only way i know how to explain it
AF Premium User
Question Re: what is the part called?
it's not leaking at the weho is it?
Old 08-18-2008, 10:19 AM
Old 08-18-2008, 10:24 AM
not exactly sure what a weho is...i know some about cars but never heard of that
Old 08-18-2008, 10:44 AM
AF Premium User
the weho is where water pump starts leaking when it go's bad it leaks out that little hole on pump.and the o ring if parts store don't have one go to menards or some place then put sylacone on it also.
Old 08-18-2008, 10:49 AM
the water pump isnt bad...its brand new so is the rubber o ring...i dont need either i need the metal tube that goes from the water pump to the lower radiator hose...one end is a little worn so i think its that...i just need to know what the metal tube is called
Old 08-18-2008, 11:12 AM
AF Premium User
ok tube they should hjave one or they can take out of a old core...
Old 08-18-2008, 11:17 AM
AF Premium User
yah and when you put tube and o-ring sylacone the hell out on it.
Old 08-18-2008, 01:41 PM
bruker's Avatar
bruker bruker is offline
I think he's refering to a "weep hole".
Old 08-18-2008, 09:19 PM
AF Premium User
it's really called a wehoe it's just a hole in the front of your water pump and it's little round hole and thats how you can tell your pump is leaking out the little round hole.
Old 08-18-2008, 09:31 PM
jjmmcs jjmmcs is offline
Bruker is right it is a WEEP HOLE!!!!
