Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-18-2008, 09:24 AM
ziggy1969 ziggy1969 is offline
Question Rear Window Washer
Hi there
The rear window washer has stopped delivering fluid.....
When I hit the button, the rear wiper moves just fine, and I can hear the pump under the hood to deliver the fluid but nothing is coming out the rear.
There is plenty of washer fluid and it still works fine for the front windshield.
I suppose I need to trace the hose and look for breaks.
Does anyone know the route that the rear window washer hose runs on a 2003 Pontiac Montana.
tia
Old 08-18-2008, 11:59 AM
rkvons's Avatar
rkvons rkvons is offline
Re: Rear Window Washer
I don't know the route, but is the pump pumping? Try removing the hose and see if fliud is coming out. Then see if the line is plugged. If it's leaving the reservoir and not making it to the back, you would think it would eventually show up somewhere.
Old 08-20-2008, 11:52 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
I believe the hose for this runs under the headliner,( between the roof and headliner). If it was leaking I would think there would be evidence , like a stain on your headliner, or a drip.Also check the sray nozzle on the rear to see if any debris may be blocking the opening.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 08-21-2008, 12:06 PM
big dave's Avatar
big dave big dave is offline
On my 2000 Montana the hose that feeds the rear kept coming off the pump which sits underneath the tank in the engine compartment. I think my 1995 Trans Port did the same thing as well.
