Old 08-17-2008, 05:08 PM
hatter03 hatter03 is offline
Re: EGR Valve problem
Hi I have a 91 ford f150 and it seems the engine rpms go up when shifting you have to rev the engine to idle it down. Could that also be egr i change idle control sensor.
Old 08-17-2008, 06:10 PM
rhandwor rhandwor is offline
Go to Auto Zone or Advanced Auto and get a free scan. Then post the codes because it sounds more like a T-P sensor. The EGR normally tends to stall the engine or make it run very rough.
Old 08-19-2008, 12:32 AM
reino134 reino134 is offline
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
I would bet on the TPS (throttle position Sensor)
Old 08-20-2008, 12:38 AM
tgore3 tgore3 is offline
Best bet is to go get you a Haynes repair manual for your truck from the parts store. It'll have directions on how to jump the EEC test port and read your codes using the CEL. Run both key on engine off and key on engine running tests. The repair manual will have the codes , how to read them, and what they mean. It'll tell you how to clear continuous codes (just remove jumper during test).
This is the one I have, which covers your truck as well. http://www.haynes.com/products/year/.../productID/161
Good site here that tells you how as well http://www.fordfuelinjection.com/?p=13
More info http://www.fordfuelinjection.com/files/self_test.pdf
I just recently got a whole lot of codes and minor problems taken care of using these. Another thing you need to do is make sure all your grounds are good. All the ones from batt to body, to engine block, just any of those ground wires you see. Check them, make sure they're clean and tight.
