Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-12-2003, 11:53 AM
rickm rickm is offline
Unhappy 22" wheels RUB
HELP
I have recently mounted a set of 22" Oasis B1's with Toyo proxes on my escalade, i notice two different sounds as s result of these new wheels.
I notice a rubbing sound in the inside of the wheel well when i turn a low speeds which i assume can be fixed by trimming the insided moulding and more importantly i notice a disturbing sound like metal bar being bent when i stop a bit more abruptly,
I want to know if anyone esle has experienced the same problems and how they can be resolved.
Thanks
Old 03-12-2003, 01:01 PM
Luke@tirerack Luke@tirerack is offline
more info please ...
exact wheel size
22 x ????
offset ????
tire size ?????
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 03-13-2003, 12:45 PM
The wheels are 22"x9
tires 305x45x22
I'm not sure of the offset but I can always find out.
I believe the rubbing inside the wheel well is the a piece inside that can be filed down.
But the disturbing one is the one that sounds like brakes grinding which i confirmed that it is not
Thanks for your reply
Old 03-14-2003, 04:15 AM
well this is an easy problem to fix ....
OE tire size
265/70-17 = 31.6" diameter
your current tire size
305/45-22 = 32.8" diameter
the correct 22" tire size
305/40-22 = 31.6" diameter
can you see what the problem is now ?????
the problem is the wrong tire size
Luke Pavlick
Old 03-17-2003, 10:24 AM
Thumbs up
Luke
Old 05-30-2003, 10:18 AM
03EXT 03EXT is offline
Send a message via AIM to 03EXT
What should be done if i already have the wrong tire size. Should i shave the plastic that is rubbing? What do u think a shop should charge for somthign like that? O and when i went to a body shop to see what he could do he said i could have someone adjust the suspenion and it would stop the rubbing... what do u think aobut that?
Old 05-30-2003, 03:10 PM
Cy@tirerack Cy@tirerack is offline
Better to trim plastic molding than adjusting the suspension it trimming will take care of the problem. By adjusting suspension, shop probably means lowering the truck which may make the truck ride harder.
As for getting it done I would recommend contacting one of our local installers by going to the following link:
http://www.tirerack.com/installer/index.jsp
If they cannot directly help you on this they may be able to recommend a local shop.
