Old 08-17-2008, 02:07 AM
jakeyf08 jakeyf08 is offline
Heater Core Help Needed!!!
I am attempting to replace my heater core on my 96 blazer and i have removed all the panels underneath the dash and i have removed the bolts on each side by the doors, i have also removed the bolts underneath the speaker covers and defrost cover. I am still missing something though because my dash still will not fold down.....any hely would be greatly appreciated.
Old 08-17-2008, 08:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Heater Core Help Needed!!!
There is 9 insturment panel support bolts.
4 under the defrost cover.
1 under insturment panel after you drop steering column.
1 to the right of lower center of dash.
1 one left side
2 on right side.
Have you lowered/droped the steering column?
Look around up in the how to section to for more info on it.
MT
MT
Old 08-17-2008, 02:24 PM
i did not drop the steering column yet and under the defrost cover i only found 2 bolts
Old 08-17-2008, 04:11 PM
MT-2500's Avatar
AF - Advisor
You will have to drop the steering column and should be another bolt on top.
Good luck
MT.
MT
Old 08-17-2008, 04:20 PM
wafrederick wafrederick is offline
Banned
Remove the whole steering column and it is easier this way with more room to work with.The advantage is you do not break the hazard button off and I have seen my father do this with him cussing.
Old 08-18-2008, 12:08 AM
thanks for the help. took about 3 hours to finish up the heater core!
Old 08-18-2008, 08:22 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
You made good time one it.
MT
MT
