Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-16-2008, 06:04 PM
justin94 justin94 is offline
Question rear end
what rear end/gear system comes in a 1994 crown vic and will an intercepter of the same year's driveshaft hook up to it?
Old 08-18-2008, 08:07 AM
reekor reekor is offline
Re: rear end
8.8 and yes the alloy shaft will hook up from the same year.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-18-2008, 04:06 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: rear end
To add, I believe the gear ratio is 3:23. If not is is real close to thar number.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-17-2008, 08:26 AM
98CrownVicKid 98CrownVicKid is offline
Re: rear end
Not sure about the aero vic's but I know some of the whales like mine (98') have a 2.73 rear end in it
When a man becomes a fireman his greatest act of bravery has been accomplished. What he does after that is all in the line of work. ~Edward F. Croker
All men are created equal, then a few become firemen. ~Unknown
Old 11-10-2008, 08:48 PM
AMDfan AMDfan is offline
Re: rear end
not sure about aeros, but 98+ usually come with 3.27s or 3.55s. 95-97 MY might also. Not too sure about earlier years though.
Old 11-11-2008, 03:47 PM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
Re: rear end
In the crown vic aeros, 2.73 is the standard rear axle ratio on crown vics with 3.27 available in the handling package, except for i believe the 01's which had 3.55's. I think the rear axle is 3.07 on panther chassis vehicles with the AOD. The rear axle gear was lowered with the 4r70w since they have a higher first gear ratio.
To find out more information about your axle, there is a tag on the axle that lists axle size, gear ratio, number of splines along with if the factory diff is limited slip or not.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
