Old 08-16-2008, 02:11 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
90 Accord
Alright, I have this 90 Accord sitting in my back yard with plans of being crushed. Timing belt went out on it, someone started changing it then stopped. I'm willing to bet its a bent valve or worse because the cam will not move.
Anyways, just wondering if you guys could think of anything I should grab off of it before it leaves. I tried to see if I could find anything on its brakes, but had no luck. My black hatch needs a new front spindle because the lower ball joint is stripped(I know I could just replace the ball joint, but I'm just gonna swap spindles). Anyone know if this would work?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-16-2008, 09:24 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: 90 Accord
nope, bolt pattern is different, and bearing size is screwed too.
Nothing from that car except maybe interior pieces would be worth anything to you... maybe the spare wiring, if it's MPFI... resistor box, injectors, TB *maybe*
basic stuff, fuses, bulbs, etc... none of the glass is the same, rear view mirror will fit if it's better than yours. Side mirrors, the glass in them MIGHT fit... pry not tho, can't remember.
If it has power locks and such, take the solenoids out, you can use them on mod projects. (shaved door kits, etc.)
Hatch struts, carpet is pretty close if you need it, but it's not perfect. *Think CRX*
AFAIR, that's about all of it.
Old 08-16-2008, 11:06 PM
Tony's Avatar
TLD Member #1
Re: 90 Accord
lmao....i knew about the bolt pattern too, it just didn't dawn on me for some reason. Its alright though, my dad finally got my integra on a trailer ready to go to the crusher, so I can go jack the spindles off of it finally.
The power locks is something I will look into though on it, I actually wouldn't mind them on my white hatch so I can get keyless entry. I don't trust my key much so I don't lock my doors.
Tony
Old 08-17-2008, 10:36 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: 90 Accord
if it's a 2 door I need to 1/4 panel for my friend who got my black one.
I doubt it tho.
why not just throw a motor in it and sell it? why do you gotta be all evil like and crush a honda?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-17-2008, 11:00 AM
Tony's Avatar
TLD Member #1
Re: 90 Accord
That was the original plan, but the car is not mine and I need it out of my yard, so that is what he is having done with it.
And yes, its a 4 door.
Tony
Old 08-17-2008, 12:00 PM
Re: 90 Accord
post a part-out in the Classifieds, see if anyone bites... best bet.
