Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 08-16-2008, 11:50 AM
catkruse72 catkruse72 is offline
water under seat
Water is leaking in the car and making puddles under the passenger seat of the car. The car is a 2005 chrysler sebring. Could the be an A/C proublem or any kind of problem with leaks. Any kind of help would be much appreciated.
Old 08-22-2008, 03:08 PM
ZR800's Avatar
ZR800 ZR800 is offline
Send a message via AIM to ZR800
Re: water under seat
Start with making sure all your drain holes are unclogged. If you search on the forum you will find some info on them. They are along the bottom of the welded seams on the body of your car.
http://www.automotiveforums.com/vbul...ht=drain+holes
2005 2500HD LS Crew Cab
Old 08-31-2008, 10:42 PM
Oldengineer Oldengineer is offline
The 05 Sebring I had did this as well. There's a service bulletin from Chysler on how to fix it. Basically, water from the A/C is running out of the heater duct under the driver's seat. Take it to a dealer as the fix is pretty involved.
Regards:
Oldengineer
