Old 08-15-2008, 07:44 PM
skipskps skipskps is offline
2005 Grand Caravan
When I turn on left blinker right blinker flashes. Right flashes intermittently when turned on. Any Ideas folks?
Old 08-16-2008, 12:49 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2005 Grand Caravan
According to the schematic I'm looking at, Chrysler, in their never ending efforts to make the biggest bucks from our headaches has integrated the combination flasher module into the body control module, better known as the BCM. That means instead of a $50 part it's now a $300 part.
It appears the only two players in your issue are the BCM and the multifunction switch on the steering column. Tough to say for sure which is the culprit but, considering price only, I'd go with the switch first. If you can use a meter you may be able to find "the smoking gun" before you fork over the bucks. You may get lucky and find "the gun" on a visual inspection of the connections.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-18-2008, 08:15 PM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
I put my $$ on the multi-function switch. What your describing is exactly what my wife's 2005 did both times the switch went bad. Its very easy to change. 15 minutes tops.
