Old 03-12-2003, 10:37 AM
Strider Negro's Avatar
Strider Negro Strider Negro is offline
Send a message via ICQ to Strider Negro Send a message via MSN to Strider Negro
A question
A friend of mine has a 95 escort wagon lx.
he wants to turbo it, but I really don't know that much about ford so hopefully you guys can help me out.
what is the name of the engine in the escort? The name of my maxima's engine is called the VG30E(this is an example).
what is the name of the engine and where can I find a site with a turbo for that engine that is if they make turbo's for that engine.
Old 04-17-2003, 11:50 AM
drag0n drag0n is offline
Send a message via AIM to drag0n
I am guessing that it has the 1.9, your best bet would be to find an EXP and take the turbo parts off of that.
Old 04-28-2003, 11:27 AM
450HPviper's Avatar
450HPviper 450HPviper is offline
It is a 1.9. Thier is no turbo kit, so find an EXP with one, or build a custom.
Old 04-29-2003, 08:49 AM
Mn93LXBoy Mn93LXBoy is offline
Send a message via AIM to Mn93LXBoy
also unless u plan on building up ur little 1.9 u could only run 3-5 psi of boost and have it be reliable
2003 Monte Carlo SS
Old 05-06-2003, 04:40 PM
RACETRACER RACETRACER is offline
a local friend run's 12 psi on an otherwise stock engine (only the injectors have been changed to protect the engine)ohh yeah ,forgot 2 .015 copper gasket spacers where used with the head gasket to get the compresion down to 8.5-1,the cost of milling and rebalancing the pistions was to high,considering the inherent weakness of the factory pistons ,also milling would only serve to make them weaker at the dish
to top that ,2 passes where made with the boost controller set to blow at 15 psi and could not detect knock(on 98 pump gas with one can of super 104 octane improver)
he is using a converted apexi SAFC and MSD dis4 ignitionw/boost retard
BUT THE ENGINE IS STOCK(sort of)
later
racetracer
Old 05-12-2003, 11:42 AM
450HPviper's Avatar
I plan on running mine on 5psi until I get some new cams and valves. Then maybe 12psi.
Old 05-12-2003, 01:26 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
I think I'll try mine at 7psi, depends on if I use a 2.0 head or not,
If the 2.0 head on the 1.9 block lowers the C/R like every one says.
Will you be using a IC?
What will you use for fuel managment?
I make slow Escorts less-slow.
My cardomain
Old 05-12-2003, 05:25 PM
450HPviper's Avatar
Yes, I think. If I can get a small cheap one.
Don't know, haven't thought about that one yet. What would you recommend?? I think you can run 7 psi with a stock block.
Old 05-12-2003, 06:26 PM
hey check this out
http://www.geocities.com/knightturbos/escort.html
later
racetracer:smoker:
Old 05-12-2003, 10:21 PM
Originally posted by RACETRACER
hey check this out
later
racetracer:smoker:
Like I'v said before, Geoff is a really nice guy and knows what he talking about, but I have seen some very poor machine work come from his shop, he does make a Escort Supercharger kit for the 1.9 and 2.0, it uses a Eaton M62 blower, but same thing here, you'll spend 3 grand on his kit, than have to take it to a nother shop to clean it up to make it usable
My cardomain
Old 05-13-2003, 10:13 AM
450HPviper's Avatar
I don't have 3 grand.
