Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-15-2008, 11:15 AM
Destroy Destroy is offline
92 Eagle Talon will not start HELP PLEASE!!!
"I have a 1992 Eagle Talon my problem is that it will not start but turns over. I checked all fuel areas and everything with that is ok. I checked spark and that is good, i then did a compression test and two of the cylinders are at 0 the other two are at 120. I took the head off and seen that two of the 16 rocker lashes were very lose and they are next to the two cylinders that have a compression of 0. Any ideas and does it sound like a valve problem. I also checked the timing belt and that is still ok."
Old 08-19-2008, 11:49 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
Re: 92 Eagle Talon will not start HELP PLEASE!!!
sounds like it jumped time to me
Old 09-12-2008, 09:44 PM
BamaboyDSM BamaboyDSM is offline
i think we may have the same problem man. I have jacked up valves. Check those man
