Old 08-15-2008, 09:19 AM
sdenney sdenney is offline
Angry Engine dies
I have a 2001 Chrysler T&C. When I initially start my van in the morning it dies - you have to give it gas (while in park) to keep it running. Shifting into gear it'll die unless gassing it. Once running for a bit it is fine & starting other times of the day it is fine. It is the initial start-up after sitting in garage all night. Any idea as to what is the problem? Hoping it's not an expensive one!
Old 08-15-2008, 06:15 PM
tempfixit tempfixit is offline
Re: Engine dies
Check the IAC ( Idle air control) to make sure the valve is moving and the solenoid is functioning.
Old 08-16-2008, 12:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Engine dies
... and clean it's port in the throttle body.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-16-2008, 07:00 PM
Rawtorque Rawtorque is offline
Re: Engine dies
This could also be the coolant temperature sensor since it happens only when cold. You need a code reader to find any trouble codes it has.
Old 08-16-2008, 08:44 PM
Re: Engine dies
Should be able to do key dance to see if any codes are present.
Igntion switch on/off, on/off, on within 5 seconds without starting engine. Codes should should show where the odometer reading is.
Old 10-23-2008, 11:12 AM
triplethreattt triplethreattt is offline
Re: Engine dies
how would you suggest to best clean the port in the throttle body? What would you use?
08 Honda Fit - 45,000 miles
08 Honda Odyssey - 32000 miles
97 Lexus ES300 - 175,000 miles
*Gone, but still in the family*
98 Gr. Voyager 200,000 miles (the last 100K thanks to these forums)
May she R.I.P.
***89 Mazda 929 180,612 miles***
Old 10-23-2008, 01:45 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Engine dies
They actually make "throttle body cleaner" and are labeled that way. I'd bet it's carb/choke cleaner, just relabeled. That and an acid brush or soft tooth brush.
Old 10-23-2008, 03:24 PM
Re: Engine dies
Thanks! I'll try that.
May she R.I.P.
