Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 08-15-2008, 06:04 AM
Flyingwhitey Flyingwhitey is offline
97 Intrepid Cooling trouble
So I'm driving along and I notice my car is steaming, so I pull over and shut it off, only to see that a torrent of coolant rushes out. So I let it sit, put some water in it for a quick fix to get it back home. Once home I take the radiator out and get it serviced to find that the tank has cracked. So I replace the radiator. After I get that in, the car still overheats. The fans don't seem to ever turn on. I get heat from the vents, but oddly enough. I've poured around 5 jugs of anti freeze in and it still won't fill up. I've check the oil dipstick for water, assuming a head gasket was the problem. But nothing. So, fans won't turn on and I have a really thirsty coolant tank. Any suggestions?
Old 08-15-2008, 06:26 PM
tempfixit tempfixit is offline
Re: 97 Intrepid Cooling trouble
How hot was the engine when you put the water in? Even if you don't see water in the oil doesn't necessarily mean the head gasket is ok. Do you see white smoke coming out of the exhaust? Coolant could be leaking into a clyinder and being burned as it runs. Doulble check for any other leaks, amd check your relays for the coolant fans. When you turn on the A/C do the fans come on?
Old 08-16-2008, 08:34 PM
AWP9521 AWP9521 is offline
I'd have to agree, if you seriously poured 5 jugs of water in the bottle it has to be going somewhere since the system only holds about 12-14 quarts.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
