Old 08-14-2008, 03:42 PM
dnelman dnelman is offline
Fuel Filter question
Hi,
I have a 2002 Oldsmobile Alero that started stuttering, sort of, last week. On the highway it will sometimes feel like it's jerking slightly and the RPMs will drop and resume during those spurts. When I'm in town it ocasionally stalls out, does this sound like a fuel filter that needs to be replaced?
Old 08-14-2008, 03:48 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuel Filter question
Welcome to AF.
Possible. How many miles do you have and has the fuel filter ever been replaced as part of preventive maintenance? You can run a fuel pressure test at the rear fuel rail Schrader valve - Around 52-60 psi for a proper reading. Plus this will test the fuel pump.
Also, what engine do you have?
Timeslip 08/12/06
AF Community Guidelines
Old 08-14-2008, 04:02 PM
Wow, thanks for the quick response! I have about 126k miles on it and no, it's never had a fuel filter replacement. Plus, I commute to work quite a distance, about 90miles/day.
Old 08-18-2008, 05:26 PM
Mike'sAlero Mike'sAlero is offline
Even if it isn't the fuel filter causing problems, I would replace it! I think the replacement interval is 30k miles.
Old 08-18-2008, 08:41 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Had a similar problem in my Grand Am. . . Shuddered real bad and was feeling like it had lost some power. It almost seemed like it would want to die at stop lights. Replaced the plugs, wires, and new fuel filter. Car hasn't ran this good in 50,000mi. +. Plus I get about an extra 30 miles to a tank of gas!
Old 08-25-2008, 11:42 PM
Alero 2.2 Ecotech Alero 2.2 Ecotech is offline
Question Re: Fuel Filter question
Hello,
I have an 04 alero with 80K miles. I have never replaced the fuel filter. I guess it's about time. So, I looked for it under the hood and had no luck. Can any tell me where it is?
Thanks,
Tom
Old 08-25-2008, 11:47 PM
BNaylor's Avatar
Originally Posted by Alero 2.2 Ecotech
Hello,
Thanks,
Tom
Located at the rear end of the car forward of the gas tank by the evaporative emissions cannister. You'll have to safely jack up the rear end and crawl underneath the car to see and replace it.
Timeslip 08/12/06
