Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 08-14-2008, 01:25 PM
Huney1 Huney1 is offline
Bigger oil filter works fine.
I found the Motocraft FL 2005 filter is about half again as long as the OEM FL 910 which is recommended. It has the same size gasket base and same size threads so why notget more bang for you buck. Bosch SKU W0133-1639046 same size as the 2005.I found the Motocraft at Advance Auto and the Bosch here http://www.car-stuff.com/mmparts/for...il_filter.html
Ford recently approved the use of Mercon V where Mercon is called for. Mercon V is half synthetic therefore tolerates friction and resulting heat better. As I understand it, no difference in the formula other than "V" being half synthetic. Please rread this before you go switching fluids. http://fullsizebronco.com/forum/arch...p/t-91461.html
