Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-14-2008, 09:20 AM
CnlK CnlK is offline
Wheel speed sensor trigger ring
Both wheel speed sensor trigger rings are cracked on the front axles. Passenger side had opened up & showed signs of contacting sensor so I removed it. Is there a two piece trigger that can be installed or would two new axles be required to bring abs back. Any thoughts appreciated, didn't uncover much with a search.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
Old 08-14-2008, 01:26 PM
rhandwor rhandwor is offline
Re: Wheel speed sensor trigger ring
I always bought rebuilt axles from this company. As they rebuild them at their location you can email and ask them. I used to pay around $99.00 to $139.00. I may be thinking of a rack and pinion.
http://www.cvsource.com/index.html I'm certain they are higher at this time. A rebuilder can buy parts you don't have axcess to so ask all they say is buy a rebuilt. I think they put them in a lathe and press on a new oversize ring.
Old 08-14-2008, 04:31 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Axlesforless.com sells them for $65/piece This is generally the recommended site on CEG since they sell GCK axles which are beefier than stock. There's a $35 coupon floating around on CEG as well. I can try and find it if you like.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-14-2008, 04:48 PM
Thanks for the tips. $65 each for the axles is a decent price, hard to find a even a wheel sensor for that price, mine were all OK, the cracked trigger rings were the source of the problem, that is the abs being activated during braking.
