Old 08-13-2008, 12:33 PM
McLin's Avatar
McLin McLin is offline
Rust on Fuel Line...
Hi,
I wantet change my Fuel Filter, but the screw from Line to Filter is full of Rust, what kiond of tipps did you have, to get the screw off, without to have a round screw?
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 08-13-2008, 01:06 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Rust on Fuel Line...
Let soak with WD-40, then use a line wrench or a vice grip...usually they are not as stuck as they look like they should be.
You'll get a lot of spray when it comes loose if you don't depressurize the line first...be ready for it...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-13-2008, 01:13 PM
McLin's Avatar
ohoh, that is not good answer... I go every hour down to the car, and spry wd40 on the screw and line... Hope thats help.
How long is the line from the Filter to???
Best regards McLin.
My Lumina
Mileage:
Old 08-13-2008, 01:19 PM
maxwedge maxwedge is offline
A990 racer
WD 40 may not free up a heavily rusted connection, , use PB Blaster or some dedicated rust busting product.
Old 08-13-2008, 01:53 PM
McLin's Avatar
mhmm, on WD40 can stand rust... But the name you say is not in stores here in Germany, but Caramba...
Best regards McLin.
My Lumina
Mileage:
Old 08-13-2008, 04:22 PM
McLin's Avatar
Is this turn correct?
Turn
Just press the hand together?
Best regards McLin.
My Lumina
Mileage:
Old 08-13-2008, 06:58 PM
DnaProRacing's Avatar
DnaProRacing DnaProRacing is offline
blaster is a good product for that, as well as deep creep. but i think if you add the right amount of pressure while using wd40 you should be fine...
92 Chevy Lumina Z34 V6 LQ1 Modified 4t60e Wot-Tech Performance Parts (1/4 million Angry Miles)
http://s284.photobucket.com/albums/ll11/DnaProRacing/
Old 08-13-2008, 07:15 PM
A990 racer
Yes and make sure you use a 5/8 6 point line wrench to avoid rounding the nut on the fuel line.
Old 08-14-2008, 01:48 AM
McLin's Avatar
Rockauto says M16, Part DORMAN Part # 800153 {Original Equipment Solutions}
Includes Seals and Gaskets Needed for Installation; Outlet; Steel Line Gasket - 3/8" x M16-1.50
ORMAN Part # 55180 {HELP! Steel Fuel Line Repair 3/8" tube x 18" Length w/compression fitting}
Includes Seals and Gaskets Needed for Installation; OUTLET: Steel Line Gasket - 3/8" x M16 - 1. 50
Best regards McLin.
My Lumina
Mileage:
Old 08-14-2008, 08:35 AM
A990 racer
M16 is 5/8 ,same size.
Old 08-14-2008, 11:12 AM
wafrederick wafrederick is offline
Banned
There are special pairs of Vice grips that grip over rusted and rounded off fasteners if the 5/8 line wrench does not work.They do work and are not cheap,about $25.00 a pair.I have seen cases the old fuel fliter has to be cut first with a recipicating saw
Old 08-14-2008, 12:49 PM
McLin's Avatar
The screw is now round, I bought the right ratchet, but the screw gives up... Now I think I must cut the line, and buy a new screw, right?
Best regards McLin.
My Lumina
Mileage:
Old 08-14-2008, 02:27 PM
A990 racer
Try vice grips.
Old 08-14-2008, 02:38 PM
McLin's Avatar
And fix the screw? I cant never useing the ratchet...
Best regards McLin.
My Lumina
Mileage:
Old 08-14-2008, 05:30 PM
sad-lumina-owner's Avatar
sad-lumina-owner sad-lumina-owner is offline
Either use vise grips or replace the whole line. No point in trying to reflare a rusty line.
