Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-13-2008, 06:43 AM
darv123 darv123 is offline
1998 Biuck Century Window Problems
My Buick rear window on thepassenger side will not go up. How can I get this window up or do I have to get a new motor? Can I just manually put it up and leave it that way? Thanks
Old 08-15-2008, 09:18 AM
prostude prostude is offline
Re: 1998 Biuck Century Window Problems
I am sure others will chime in on this
from what I understand you can pull the door panel manually push up the glass and put a clamp in the rail to hold it up
Dealers usually charge about 80.00 to do this and about 600 to put in a new motor if that is the problem
Old 08-17-2008, 09:54 PM
Sterling52 Sterling52 is offline
I'm in process now of putting a new regulator and motor in the rear myself. I have a 2001 century basically same as yours. Remove the door panel and motor and regulator are bolted in, which makes it easy to remove. Then get on e-bay and you can bid on a new one for $50.00 to $60.00 dollars, shipping including. Easy fix and not to expensive. GM priced me the regulator and motor for $426.00.
