Old 08-12-2008, 10:28 PM
82Stang 82Stang is offline
Runs extremely rich...
Hello,
1993 Chevy S10 Blazer 4.3L 4x4 auto Vin W
Started running poorly intermittently, sometimes it ran bad for a little bit then it was fine. The other day it stayed bad (black soot exhaust left on ground)and nearly left me stranded. Engine light revealed a code 45 (O2 sensor rich) condition. Problem is, I got another O2 sensor and went to remove the old one and couldn't budge the darn thing. I ran the vehicle for a little to heat it up and still couldn't budge it, my body weight with pipe extension and wrench extensions too. I succeeded in rounding off the ends. Now I'm just short of breaking off the head and trying a box end wrench or socket. But once I do that, I really have to fix it right then. Anyone have any ideas for me to possibly get this off without having to do that yet? I don't have torches.
Thanks.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 08-13-2008, 08:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Runs extremely rich...
Cut the wire off and put a good socket or pipe wrench on it.
But
A good muffler shop may be the best way to go on 02 sensor.
They deal with them all of the time.
Many have messed up threads.
The 02 is probably not the problem on running rich.
Check fuel pressure for fast leak down.
You may have a regulator leaking or nut kit flooding it with gas.
MT
MT
Old 08-13-2008, 09:20 AM
But
MT
One thing I know is: it's a lot easier to check the regulator than get the O2 out. I'll try that first. Thanks.
Rodney Dangerfield
Old 08-13-2008, 10:15 AM
MT-2500's Avatar
AF - Advisor
10-4 on that.
02 sensor may not even be bad.
Code says check it out not replace parts.
Also watch the tempt sensors and egr valve for sticking open.
And check the evap canister.
MT
Old 08-13-2008, 11:59 AM
10-4 on that.
yep, will do...
About the evap? What to check for? I think I read something about if it was wet then it's bad and change it. Not sure...I have a spare regulator and egr.
Oh, before it started running funny, it started taking a bit to start it in the morning. It wouldn't start right up anymore, I had to give it gas.
Rodney Dangerfield
Old 08-13-2008, 02:02 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Putting the socket on it is the way to go. I further(if I have to) warm up the area around the o2 sensor. The idea here is to just expand the metal around the sensor and not the sensor itself.
Old 08-13-2008, 05:25 PM
MT-2500's Avatar
AF - Advisor
Originally Posted by 82Stang
yep, will do...
Remember proper testing before throwing parts at it.
Get a fuel pressure gauge on it and check for proper pressure and fast leak down.
If canister is wet unplug it and plug vacuum line from engine and see if engine starts running better.
MT
MT
Old 08-13-2008, 11:10 PM
MT
MT,
I was monkeying with it for the past 4 hours and here's what I noticed. I tried unplugging everything, one at a time, to check that particular sensor. TPS, MAP, IAC, EGR, O2 sensor, ATS, temp sensor. None of these did anything except some made it worse, some didn't and shoot codes. So I cleared the codes and started over, no codes now, not even for O2, but still running very poor and barely keeping running. When I give it alot of gas it almost sounds like it wants to clear itself up, but returns to very poor again. Smells gaseous. So glad the O2 wasn't it, but now I am still wondering. As for the fuel pressure and evap(not sure where it is), didn't get to that yet. Tried coil, but no go. I was searching and supposedly there is a fuel port on the rear of the intake somewhere. The evap I couldn't tinker with, didn't know where or what it looks like. The fuel pressure regulator sounds like a good possibility, but I saw online that it is internal with the CPI so how do I check that? Could a head gasket be a possibility also?
Thanks for your help.
Rodney Dangerfield
Old 08-14-2008, 07:22 AM
MT-2500's Avatar
AF - Advisor
As in post no 7 start with a fuel pressure test.
If it is leaking or nut kit you will have a fast leak down.
MT
MT
Old 08-14-2008, 08:23 AM
stgen stgen is offline
Try putting breakfree on it for a few days,the hot and cold cycle from driving and sitting should help it loosen up.give it a few days though before you try it again so you give the breakfree a chance to work.Also if you have rounded off the end of the sencor,try useing a pipe wrench on it with your breaker bar.It works for me.
Old 08-14-2008, 09:08 AM
Yes. Thanks, but it isn't the O2 sensor.
Rodney Dangerfield
Old 08-15-2008, 02:28 AM
534BC 534BC is offline
If you don't have a gage, then to test for a leak in the intake turn key on every so often (5-60 minutes) for a dozen or less times.
See if it starts very badly and smokes upon startup far worse than normal. If it doesn't start (hold to floor to get going) then it has a leak in the intake.
If so yours has got to be a huge leak and can be spotted quickly by removeing the top plenum and turning on key.
Old 08-15-2008, 06:49 AM
Interesting. I'll try that.
Rodney Dangerfield
Old 08-20-2008, 10:32 PM
MT
MT,
I have been away for a while so just now getting back to looking at this. Here's what I got for fuel pressure.
KOEO - 50psi
then after 2 mins, down to 36psi and would prob keep going if I let it.
KOER - 55psi and holding steady.
Starting to think I didn't change the wires and cap/rotor when I got it. May start with that because I checked just about everything else except the cat.
Rodney Dangerfield
Old 08-30-2008, 11:59 PM
cmoney2 cmoney2 is offline
check plugs if one side is black its the FUEL PESSURE REGULATOR. diaphram has ruptured causing raw fuel to enter the pelnum
