Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 08-12-2008, 05:01 PM
inkslinger00743 inkslinger00743 is offline
1996 concorde no heater/ac, windows dont work,abs light
My car started acting up in the past week. The ABS light will come one when I start the car. while the light it on the AIRBAG light also comes on. The windows will not roll up or down and the heater/ac will not work. The door will lock but not unlock. At first I would have to keep restarting the car and everything would be fine but now its stuck. I have tried disconnecting the battery, check fuses and relays. Everything seems fine.
Old 08-24-2008, 12:35 PM
allensEddieB allensEddieB is offline
Re: 1996 concorde no heater/ac, windows dont work,abs light
This is what I found when I had the same problem. it helped me I changed fuses #13 & 14 even though they looked fine.
Question
Hello,
I am having problems with my Anti-theft device. On Saturday I went to get into my 1996 Chrysler LHS and there was no power lights on the inside of the car. Immediately I knew there was a problem with the Anti-theft because this has happened before. I proceeded to lock and unlock the front doors using my key, and after 1 1/2 hrs. I was able to get the lights to come back on in the car, but when I tried to start it, the car would click on partially then die out. After trying this for a few times, my boyfriend and I tried to reset the battery and then charge it. The car will still not start. If you could give me any tips that would be great. I have someone coming over today to try to disconnect the system (maybe that will work ?)
Answer
Hi Sara,
I would suggest that you check fuses # 13 and #14 to see if they are either blown or have a small crack in their wires. If that is ok then try the trunk lock similarly as you have the door locks.
It is unclear to me if you can't get the starter to work or the engine to start (which is unrelated to the theft system) or instead that the engine will start but then dies in about 1-3 seconds (which is what happens when the theft system is in an alarmed state). So tell me about that.
I would not try to disconnect the system as it is built-in to the body computer and cannot be disconnected without messing up the communication from there to the engine controller which will then assure a No Start condition.
Let's try to fix it, not remove it.
Roland
Old 08-24-2008, 04:09 PM
i found out the problem it was the ignition switch. it cosed 30 bucks and everythings back to normal. thanks for the replies though
Old 05-10-2009, 07:04 AM
mr_dave00 mr_dave00 is offline
Had the same proble and it was the ignition switch and a corroded termianl causing a arc.
