Tire size correction?
I got done early at work today so I decided to bring my 2004 Cavalier in the shop and play around with (er, uh, I mean learn) our relatively new Tech-2. I was going to correct the tire size while I was in there (speedometer off by a few percent), but I couldn't go into 'Chassis', each time I got the same 'no communication' error. 'Powertrain' and 'Body' worked fine, I could see all data and command everthing on/off so I know the connection was good. Should the Cavalier have anything under 'Chassis'? If not, does anyone know how to correct the speedometer?
Thanks
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Re: Tire size correction?
The Vss is located in the drive train. I've never got my hands on a tech 2, but I know how to do it with HP tuners.. lol
PPM= Pulses Per Mile Diameter= The Diameter of the Tire PPM x (Old diameter/New diameter)= new PPM Example: 24212 PPM x (25"/23")= 26392 PPM go to speedo option it brings up "VSS Pulses Per Mile" See if you can find it in the transmission setting somewhere since the VSS sensor is that. Not chassis...
Please don't PM me with your J-body Issues. Post appropriately in the forums, and I will toss my opinion in your thread if I have anything to help. - Thanks! 2006 Chevrolet Trailblazer 2010 Glastron GT 205XL |
I checked out the HP tuner website, I might have to get one of those, maybe I'll try to talk my boss into buying one for the shop first
![]() In the Tech-2, the tire correction is in the 'Chassis', at least on trucks. I've seen it in there several times, but never wanted to risk playing around on a customer's vehicle. When I left today, tomorrow wasn't looking very busy... maybe I'll take another look. And you've got a PM
