Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-12-2008, 04:26 AM
EngineandJuice EngineandJuice is offline
EGR Valve
While taking a trip through the junkyard this weekend to grab bolts off an egr valve since the ones that were holding the piece of metal in place where my egr valve was suppose to go didn't fit when I put the aftermarket egr valve on, I decided to snatch the whole egr valve off an 80 something firebird. The part number on it is 17084735. I looked online and also ran across another number a few times while looking this up which was "EGR353".
Question is will this EGR valve work in my car? If so I'd throw it on til I can afford to grab a new one from the dealer.
Old 08-12-2008, 09:06 AM
Cgroh89 Cgroh89 is offline
Re: EGR Valve
If you took it off of a Carb'ed Firebird you should be fine. I did a quick check with some part numbers I have and they seem to match just the 305/350 till they changed over to tbi/tpi
Old 08-13-2008, 11:47 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: EGR Valve
I can answer you this.
I just went out and looked at the number of my own EGR valve and it is this:
17084735
So yes, I think it will work!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-14-2008, 03:20 PM
Re: EGR Valve
I think Silicon has tapped into the Force or something he can't be this good.
