1995 chevy lumina sedan died while driving. I now have no electric power to anything. Battery registering 12.9V, ignitinion fuses look good. What could be the problem?
Re: total power loss while driving
check both ends of your cables for loose connections or rotting cables. check all fuses good luck
oh yeah make sure the pos. terminal is secure they have been known to just completely pull out of the battery and leak acid, this batteryis under the washer tank right?
battery new. checked all connections. i have power to the fuse block. cant figure out why no power to anything. It was running fine, just suddenly died while comming home from work.
Check fusable links down at the starter. Primary wire sections that burn through when overloaded.
You talking the fuse block under the hood or the dash box? Courtesy lights in the interior? Key in ignition chime? Anything?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
i know my son had one and it was bad on coils..
I got it. aparently with all the junk Chevrolet thinks needs to be under the hood I couldnt tell the ground was barely loose from the battery. took it off and cleaned, it fired up as always.
Thanks guys |
