Old 08-11-2008, 06:11 PM
chocolateducttape chocolateducttape is offline
differential service?
So, I have an '05 F-150 and I took it to get oil changed and tires rotated today. Every time I've gone for an oil change, they've advised that I get my rear differential serviced. But the first time I went they said not to worry about it until it hit 45,000 miles (I'm at 32k right now and was at 10k at that point). I haven't pulled a trailer with it in the year and a half that I've had it, and am unlikely to do so in the immediate future. Does anyone know when I should actually get that taken care of?
Old 08-11-2008, 08:32 PM
wafrederick wafrederick is offline
Banned
Re: differential service?
If it does not make any noise,leave it alone and the dealer is trying to do something unneeded.Only thing to do is change the gear lube once in a while and if it has a posi,put in posi traction additive you can get at most parts store.Put the posi traction additive in first before the gear lube if it has posi traction.
Old 08-11-2008, 09:01 PM
jd-autotech jd-autotech is offline
im sure the info you need is in your owners manual or the dealer will provide you with a maintenance schedule
Old 08-20-2008, 01:10 AM
tgore3 tgore3 is offline
05 prolly has synthetic in it. Good for the life of the truck usually, unless something happens like heavy usage, water getting in, or a leak. Those places are always trying to sell people things they don't need. They seem to use a set maintenance for all vehicles. It use to be that all vehicles were pretty much the same but not these days.
Looking at the 05 F-150 schedule normal driving, I see nothing about rear diff service. Towing it shows every 60k. Check it out, put in your truck's info and your driving conditions.
http://www.genuineservice.com/genuin...ault?page=Home
