Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-11-2008, 03:34 PM
jrbueiz jrbueiz is offline
Radiator Replacement
'99 Tahoe - 4WD
For those of you who have replaced a radiator before; Do I need to do anything special with the oil (oil) cooler, transmission (fluid) cooler pipe lines?
If so, what's a good method for plugging up the lines while inwork?
Also, does anyone know if there are benefits to installing a "Heavy Duty" radiator, AND whether or not it would fit comfortably in the stock location? I'm grabbing one from Autozone with Lifetime Warranty. Here are their dimensions:
Heavy Duty:
2 row, 34" X 17 1/4" X 2 1/4"
Regular:
1 row, 34" X 17 1/4" X 1 1/4"
The difference between the two is approx. $30.
1999 Chevy Tahoe LT 4x4 - 4 Door
5.7L 350cid V8 FI (R)
Old/Heritage Body Style
Old 08-12-2008, 01:48 AM
exwldr exwldr is offline
Re: Radiator Replacement
measure and see i you have the space to accomadate the extra 1" thickness remember the fan shroud will be moved back also & you still need room for ac condenser & oil cooler. fan blades may be a clearance issue!!if not then go with the heavy duty . my '96 tahoe has it as a factory option, definately worth the extra bucks,a loaded 5.7L 4x4 can never run cool enough. exwldr
