Old 08-11-2008, 12:41 PM
troyky29 troyky29 is offline
97 Blazer shifting
I have a 97 Blazer auto transmission, with the 4.3. I am trying to get an idea of the problem before I send it to the shop. When driving after it has been sitting, the transmssion shifts thru all the gears fine. After driving a couple miles, I lose 1st gear and overdrive. 2nd and 3rd work fine. It takes off in 2nd gear and then 3rd thats it. It can sit a couple hours and shift fine for a couple miles, then back to just 2nd and 3rd. I would'nt think that this is transmission failure, maybe something electrical? Any input would be great! Almost forgot, trans was rebuilt about 10,000 miles ago.
Old 08-11-2008, 02:12 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 Blazer shifting
If it is going to the shop let them figure it out.
That is what you will be paying them for.
Needs put on a transmission/engine capable scanner andf check things out.
If any codes transmission or engine post back code
MT
MT
Old 08-11-2008, 02:23 PM
Just wanting to know if anybody has ran across this problem before. If it is something simple, maybe I can avoid shop costs. I am sure I am not the first person to encounter this problem. Even if I do take it to the shop, I would like to get a rough idea to what the problem is.
Old 08-11-2008, 06:09 PM
MT-2500's Avatar
AF - Advisor
You will have to get it on a transmission/engine capable scanner to see what is going on.
Check for codes and shift adpative data and slippage and check shift solenoids.
MT
MT
Old 08-15-2008, 01:52 PM
Took to Oreilley Auto and ran the codes. Came back as Transmssion shift solenoid malfunction. Hopefully this solves the problem.
Old 08-15-2008, 02:12 PM
MT-2500's Avatar
AF - Advisor
That does not say much.
You need to get it on a transmission capable scanner and find out which one a why.
And do not forget the 97 is a bad year for ign switches that can cause that problem.
Take it back and let the shop check it out.
MT
MT
