Old 08-11-2008, 12:04 PM
sooowild2000 sooowild2000 is offline
Keyless entry 1994 Chevy Camaro...
Can anyone tell me if this is the same for the 1994 Camaro Keyless entry programming. I found this for a 1996 Camaro. Thank you.
From an e-mail I recieved: 96 Camaro keyless programming--
1- Turn ignition off. Remove RADIO fuse (fuse #17) from the fuse block. Cycle the ignition switch from OFF to RUN 3 times within 5 seconds until door locks and hatch release cycle. Indicating the BCM is in program mode. Leave ignition key in RUN postion.
2- Press both LOCK and UNLOCK button on Transmitter for 16 seconds. Door locks will cycle (LOCK then UNLOCK) confirming the transmitter has been programmed. Door locks must cycle completely to unlock before proceeding.
3- Repeat step (2) for each additional transmitter to be programmed.
4- Turn off ignition switch, and replace fuse #17. confirm fuctions of transmitter.
If you have an LED from the factory, mounted on the top of the dash pad, I can also send you instructions on how to program the different modes of the factory alarm.
