Go Back   Automotive Forums Car Chat > Mazda > 6
Old 08-11-2008, 09:46 AM
chuckrys1260 chuckrys1260 is offline
Smile programming new remotes
If you change your battery in your remote for this vehicle, do you have to reprogram?
Also if you buy a new remote does anyone know how to reprogram without going to the dealer?
Old 08-13-2008, 03:18 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: programming new remotes
Try This:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
