2000 Bonneville-A/C blows only on one side
My 2000 Bonneville only blows cold air on one side (passenger) warm air blows on driver side. I have Electronic Climate Control. Can someone help?
Re: 2000 Bonneville-A/C blows only on one side
Man, I can't believe no one responded to this one.
![]() For warm air driver's side and cold air passenger side first thing to check is for a low refrigerant level. So check the R134 charge at the low side service port and make sure it is in specs based on the ambient temperature and humidity of your area.
I agree- very typical
Very typical low charge scenario- your system has leaked out more than half the specified refrigerant amount- the evap entrance cools first- which just happens to be the portion that feeds the passenger side- the exit feeds the driver's side- find and fix your leak and evacuate and recharge to factory spec-- number one leak location is compressor shaft seal followed closely by compressor belly (case halves) leaks.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Thanks for the input on my problem. One thing I did not mention in my previous thread. I have dual zones in this car. Does this change anything you told me in your reply to me? I've heard that it could also be the diverter door/s and this is an expensive fix. Is this true? thanks again for any replies.
I've seen a couple of temp door problems- but they are usually just the rods come unhooked- pull down your glove box- all the way, and have a quick look- there will be a rod on top and a rod on bottom of HVAC unit- run temp control to full hot and to full cold- watch temp doors move- look for binds, jerks, and make sure rods are fully attached.&
The vent/blend doors in the HVAC assembly are actually controlled by temperature actuators (motors) that move as you adjust temperature, of course driver and passenger sides are independent. They can cause a similar issue. Regardless of whether you have dual or single zone check the refrigerant charge first and for any leaks since it is easier. The temperature actuators are harder to get to and located in the dashboard. Replacement is not fun either.
