Old 08-10-2008, 07:56 PM
primal1469 primal1469 is offline
how in the frick
how do i get the old 6x9s out to put new ones in
Old 08-10-2008, 08:57 PM
m0ng00se m0ng00se is offline
Re: how in the frick
You will have to remove the seat in order to gain access to the rear deck. Its really simple but has a learning curve of course.
The bottom of the seat you can pull up in the front and then it should slide right out. Remove the 2 or 3 bolts holding the back seat and seat belts in place and set those aside.
Slide the bottom of the seat off of the bolts and then push it up and pull it out. Might take some work but it will come off. Once both parts of the seat are out of the way, you can remove the rivets that hold on the back deck cover and voila, 6x9's!
Old 08-10-2008, 11:30 PM
cookie197722 cookie197722 is offline
Man, all that to change speakers?
Old 08-11-2008, 10:14 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Depends on how badly one wants new speakers. If I needed them, this is what I would do....
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 08-11-2008, 10:34 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
If your putting aftermarket in, be sure to flip the radio on and see if you like the sound before you put it all back together....
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-11-2008, 10:43 AM
Highbeamz Highbeamz is offline
It's really not THAT hard. I replaced mine some time ago...I typically take 2-3 times longer to do a job the first time through, and I got them done in less than 3 hours...and that includes time to run inside and search the internet to find out what wire is what...make sure you find a wire diagram before you start just to make it easier...make sure positive goes to positive, you know.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 08-11-2008, 11:06 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
It is actually very easy, the first time I did it on my car it took about an hour. I helped a buddy change his and it took less than 45 minutes. The reason it is so involved is because the speaker grills are part of the rear shelf and cannot be removed separately, and the screws that hold the speakers in come in from the top.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 08-11-2008, 11:50 AM
I can definitely vouch that it can be done in an hour or less. Just tug the bottom of the back seat out (2 minutes), unbolt the upper rear seat and remove (5 minutes or so), pull off the rear cover, unscrew the speakers, cut/remove the wires. Install is just the opposite, just make sure you use some quality connections if you want it to last...personally I use decent quality butt connectors, I've never had a problem with them...just make sure you crimp them FULLY.
14x,xxxkm's
