Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-10-2008, 06:35 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Car not running well
I have a 1991 Eclipse GSX. I have most standard bolt-on mods including intake, exhaust, 16g turbo, fuel/water pump, injectors, new headers, my battery is relocated in the trunk. Starting yesterday, as soon as I rev the car to about 2200 RPM, it starts backfiring horribly and will not go into boost. It almost sounds like its bouncing off of a rev limiter. I;ve tried a few things that some friends recommended such as replacing my spark plugs, checking the ignition plug is in securily, I swapped my MAF out with a friends to make sure my MAF didn't die on me, checked the timing belt for skips, cleaning the throttle body and idle control motor. Does anyone have any ideas on what could be the problem?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
