Go Back   Automotive Forums Car Chat > Saturn > Relay
Old 08-10-2008, 05:41 PM
auroralover auroralover is offline
Car starter problems
My aunt has a 2007 Saturn Relay, it is a really nice van. One of the remotes needed a battery, it was replaced, so now when you press lock and then the start button on the fob it fails to start, all it does is honk like someone has attempted to break in the car. I am assuming this is a programing issue.
Thanks
Old 08-10-2008, 05:44 PM
jd-autotech jd-autotech is offline
Re: Car starter problems
you may need to have the remote resync. is there another remote?
is the remote start factory or aftermarket?
Old 08-11-2008, 10:06 AM
Smile Re: Car starter problems
The van has Factory remote start and yes there is another fob.
Thanks for your help
Old 08-11-2008, 03:20 PM
if you gather both remotes and hold the lock and unlock buttons all at the same time either for 10 secs. or 3 times cant remember which or ask your local dealer it has been awhile since i messed with that kinda stuff
Old 03-11-2009, 02:02 PM
saturntech's Avatar
saturntech saturntech is offline
You can only reprogram these fobs with a scan tool. If your relay is the up level, you can Personalization some options for the vehicle through the DIC. In there is a setting to turn on and off the remote start, I would check to see if you or some 1 has turned it off.
This is how you access it:
Press the menu button until REMOTE START appears on the DIC display. Press the set/reset button to scroll through the following choices
OFF: The remote start feature will be disabled.
ON (default): The remote start feature will be enabled.
Old 03-11-2009, 02:06 PM
saturntech's Avatar
Sorry about the old post, wasn't paying attention
