Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-10-2008, 05:30 PM
musicteacher musicteacher is offline
Coolant Leak
My '99 Intrigue is leaking coolant but my mechanic can not find where. Everytime I drive it I have to fill the overflow tank. When I park the car I see fluid on the ground but can not see where it is coming from. The hoses appear to be fine and the mechanic wants me to commit to a $500 repair bill even though he doesn't know what's wrong after putting it on the lift and checking. Any ideas from anyone?
Old 08-10-2008, 05:32 PM
jd-autotech jd-autotech is offline
Re: Coolant Leak
time for a new mechanic first of all there are pressure testers out there or dye can injected into the system to help locate leaks
Old 08-11-2008, 01:37 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: Coolant Leak
Yeah, a second opinion is definitely in order. There are better ways to find leaks than just taking a look under the hood, and JD listed them.
Personally I wouldnt take it to the dealership, theyll charge you 25 bucks just for pulling their parking lot.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-31-2008, 02:36 PM
dizzle1's Avatar
dizzle1 dizzle1 is offline
Re: Coolant Leak
Don't bother a mechanic unless he finds your problem. I went to chevy once and they want a 100 just to check your car because they think they got the magic touch lmao hell with dealers. The 100 won't apply to the work either if you'd pay.
Look at the bottom of the car a 1/2 hour after you stopped driving better in a garage its like water it could evaporate
Old 08-31-2008, 08:46 PM
sabrds sabrds is offline
Re: Coolant Leak
Just had a "no see um" coolant leak fixed on my 01 Intrigue. The problem came from the coolant crossover pipe that supplies coolant to the cylinder heads. The gaskets were leaking since I flushed out the orange, thick Dexcool radiator fluid and replaced it with the standard green fare. It took my mechanic a mirror and about 20 minutes to find. Trouble is, most of the intake maniforld meeds to be removed before the gaskets can be accessed and this can be rather costly.
Hope this helps!
Old 01-30-2009, 02:33 PM
o2man o2man is offline
Re: Coolant Leak
Had the same problem recently, it was a cracked intake manifold. I was told it was common on the 3.8 because of the plastic intake. Part was about $150.00, the labor about $250.00
Closed Thread
