Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-10-2008, 03:47 PM
tahoe4x4guy tahoe4x4guy is offline
2001 tahoe hard start
I just changed the plugs in my 01 tahoe because it has hard to start. At first it started good and now a week later it still starts hard again. I was look for some advice on what else it could be.
Thanks Tahoe4x4guy.
Old 08-10-2008, 08:59 PM
exwldr exwldr is offline
Re: 2001 tahoe hard start
have you looked at the plug wires. does it seem to be missing a cylinder when it's running? when you put in the plugs ,did you check the gap before putting them in? i hope you didn't use champion plugs , because chevys don't run worth a damn with them..one of the engines ignition coils could be going bad.you can check wires & coils with an ohm meter.. exwldr........
Old 08-11-2008, 04:02 PM
no it's not missing when it is running and yes i did check the gap and they are champions.
Old 08-11-2008, 06:23 PM
maxwedge maxwedge is offline
A990 racer
I'd check the fuel presssure next, need at least 58psi.
Old 08-12-2008, 01:26 AM
yes i agree i would suspect a fuel problem verify pressure is good. next i would look at the fuel filter, has it ever been changed? i have seen these things clog up in as little as a few thousand miles. exwldr
Old 08-14-2008, 05:55 PM
I thought it might be fuel but the part i don`t get is when i start it with the remote starter it fire`s up no problem.
Old 08-16-2008, 12:57 AM
i assume you are hooking the remote starter right to the starter solenoid.? if so that means you're bypassing the neutral safety switch . which tells me it needs to be checked out. i hear they are a common problem on tahoe's & suburbans.....exwldr
