Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 08-10-2008, 11:27 AM
Bassigns Bassigns is offline
hey guys need your help 93 convert wobbels
seems it's gotten a lot worse
93 lebron convert
so far i've changed struts, shocks, and new sway bar bushings BUT the car wobbels like crazy so much so i don't want to drive it anymore
it does not pull and you can not feel it throught the steering wheel and i can't figure it out - does seem the drivers side frt tire does not spin too freely compaired to the passanger's side
thought it might be the caliper sticking but if that was the case the car would pull
any ideas
Thanks
steve
Old 08-10-2008, 11:36 AM
Re: hey guys need your help 93 convert wobbels
as a side note i do think i need a cv joint - if they are bad will the car wobble?
thanks again
Old 08-11-2008, 11:43 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yes, they can. You can check the CV by looking at the boot. If it's seal then it might be alright. If not then I would assume it's toast. You can also check it by moving it around and seeing if there is any play.
Old 08-14-2008, 12:20 PM
Joric LeBaron Joric LeBaron is offline
I'd check for an egg in the tyres.. swap the front with the rears and see what happens
Friends don't let friends drive a 'ricer'..
Old 08-14-2008, 01:36 PM
Cgroh89 Cgroh89 is offline
I had a wobble issue with my other halfs car turned out to be a snapped band in the tire, Does it do it at all speeds?
Old 08-17-2008, 11:46 AM
Thanks and yup all speeds
Old 08-17-2008, 01:40 PM
Thanks for the tip.. just swapped the tires and the wobble is still there - more pronouced when speeds are over 35.. tires look fine ie no eggs or no snapped belts
driving me crazy as the car looks good and runs good but i can't figure this one out
Old 08-21-2008, 11:08 PM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
Are you sure your tie rod ends are good? And your steering rack?
Old 08-22-2008, 05:37 AM
not too sure.. i dropped the car off at a local shop the other day and the guy mentioned the rim was dented and out of balance. funny thing is that when i rotated the tires i did not see any indication of that.. said he rotated the wheel and tossed it on the rear (even though i rotated the tires on sunday) and i have never seen an out of balance rim cause this type of wobble - it was very very bad..
car seems fixed even though you can still feel a slight wobble when taking a sweeping left turn. game plan is to find some cheap rims (steel wheels) and put new tires on the car
Thanks again everyone for your tips and suggestions.
Old 08-26-2008, 09:52 PM
Go to a junk yard and find some good tires on steel rims. Go to a tire shop and have them put new tires on those rims, then sell the junkyard tires.
Old 10-03-2008, 03:09 PM
Caleene Caleene is offline
Steve,
I had the same problem. I got new front axles, tires, shocks, and struts and still had that wobble. It happens when you accelerate and you can feel it in your seat. This may sound wierd but check your motor mounts. I had mine replaced and my car drives smooth now. I had a 66 Mustang that had the same problem that's how I knew to check them. Good luck.
Old 10-03-2008, 03:12 PM
will do as it seems like it's getting worse (haven't driven the car in a few week)
Thanks for the advise
