Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 08-10-2008, 08:58 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
The project begins....
Well I started pulling the engine this weekend. I've just got to finish disconnecting the wire harness and transmission and I think I've got it. My buddy will be getting me an engine lift for next weekend. Thats when I hope to have the whole thing done by!
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 08-10-2008, 03:42 PM
GForce957's Avatar
GForce957 GForce957 is offline
Re: The project begins....
Nice, good luck! I will be starting mine soon
Old 08-10-2008, 10:53 PM
MZR_47's Avatar
MZR_47 MZR_47 is offline
Send a message via MSN to MZR_47
what engine are you putting in? I missed it if you mentioned it in another thread. And am FAR too lazy to look.
MOAR BOOST
Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi
Old 08-11-2008, 08:17 AM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
I don't think he is doing a swap. With the 300ZX, Nissan took an engine bay that would work with say, a small four cylinder motor, and then shoved the biggest physical engine they could in there. To replace the turbos, you'd have to pull it.
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 08-11-2008, 09:16 AM
BeZerK2112's Avatar
^^^ DING DING DING! We have a winner!
I have to replace the turbos. The ones in it are warn out, and the driver side turbo has blown a seal so my exhaust is now an oil line! You thought sea foam was bad...
I actually found a guy who did an LS1 engine swap. He was featured in SportCompact. He's got more room in the engine bay then I do!
[center]
Old 08-11-2008, 09:35 AM
craig34's Avatar
craig34 craig34 is offline
Good luck, of course you cant keep it stock.
Old 08-11-2008, 09:46 AM
MZR_47's Avatar
makes sense. I did see the thread with the new (to you) turbos and was curious where they went. I know nothing of Nissan, hence my ignorance.
That does seem pretty stupid that an LS1 fits in the bay better than the stock motor... nissan engineering at its best.
MOAR BOOST
Old 08-11-2008, 02:52 PM
CassiesMan's Avatar
AF Vendor
Just be sure to disconnect everything...
*Flash back to working on the "VR4"*
K&N|Falken
Old 08-11-2008, 04:58 PM
BeZerK2112's Avatar
Got a guide from a Z forum. Very detailed on what to disconnect. Having a great time right now with it. More pictures to come I'm sure!
[center]
Old 08-13-2008, 09:45 AM
BeZerK2112's Avatar
Get this! When I was working on the car yesterday I was unbolting the AC compressor and found the OEM Radiator cap! Man I was excited. Even though the radiator wasn't in the car, I replaced the broke cap and put the OEM one on. Technically now I'm back to stock...
[center]
Old 08-13-2008, 11:27 AM
CassiesMan's Avatar
AF Vendor
Epic win... Do you have a thread for loosers like me to follow over in the project car section?
K&N|Falken
Old 08-13-2008, 05:49 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yeah, you should start one in the project car forums.
Anyhow, found the OEM rad cap huh? I wish I could have found mine because Japanese lettering adds a minimum of 5 hp per character. Not only that, it's a sleeper add on since people can't see. I know when I see a car with Japanese lettering I don't even get near it cause' that's a major ass beating waiting to happen.
Old 08-13-2008, 11:40 PM
MZR_47's Avatar
Just ask anyone who has messed with a Hayabusa.
MOAR BOOST
Old 08-13-2008, 11:47 PM
Polygon's Avatar
The Red Baron
At least until they hit a turn.
Old 08-13-2008, 11:54 PM
MZR_47's Avatar
Then you can laugh at them as they pull themselves from the Busa that is now wrapped around a tree.
MOAR BOOST
