Old 08-09-2008, 07:34 PM
nicenshyguy nicenshyguy is offline
97,cavalier wont start
car wont start turns over starts for a sec. then stalls cheked fuel pump sendding lots of gas and has good pressure..but not sure if it's enuff...if anyone can give me ideas or tell me whats wrong with this damn thing i would be very appreciative....thanks
Old 08-09-2008, 07:39 PM
inafogg inafogg is offline
Re: 97,cavalier wont start
try spraying carb cleaner in the intake.
Old 08-11-2008, 09:09 PM
tryed that still didnt do anything..all it did was back fire and cath on fire for a sec...
Old 08-11-2008, 09:14 PM
Aaron_0703 Aaron_0703 is offline
yo u can check the spark plugs or even the boots or the starter even tho it still starts for a couple of seconds. or go to a chevy dealer an tbi the cavalier
Old 08-11-2008, 09:15 PM
jd-autotech jd-autotech is offline
call the dealer there is a recall for a starter relay harness addition to a lot of cavilers
Old 08-11-2008, 10:40 PM
ight listen this has to be it i have a couple different problems it may be... loose connection with your ignition coil... not enough fuel going to the injectors may need new ones.... vacuum leak between the manifold and the throttel body..... engine controll system could be screwed up.... or ur intake mite be leaking so it could cause a vacuum line to break try an check all of these get like a manaul or just do wut the other guy told u take it to a dealer an have them check all of these
Old 08-12-2008, 03:27 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Which engine does it have?
Check for codes, especially the theft system. Also make sure the IAT, ECT sensors read close to the actual temp. You could also just unplug them and see if it runs, sometimes they will, sometimes they won't. Check the MAP sensor and hose.
Did you actually check fuel pressure or just see "lots of gas"? Put a pressure guage on it and try to start it, If the pressure drops once it starts the pump is bad. That's very common on GMs.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-20-2008, 11:23 PM
r1bourg r1bourg is offline
Ignition wiring harness did this to me. It slowly failed to start. Had no idea until my son the mechanic said it could be the wires. Changed wiring harness and all is fine now.
