Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-09-2008, 04:59 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Car sputters and tranny doesn't shift
Watch the video: http://s54.photobucket.com/albums/g1...amaro_sick.flv
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 08-09-2008, 07:39 PM
Morley Morley is offline
Re: Car sputters and tranny doesn't shift
I heard no sputtering in your video, nor did I see anything from the tach that suggested sputtering. HOWEVER! I did see your oil pressure gauge needle was all over the place and from outside (when you let the engine idle down) it sounded like a pretty large vacuum leak.
Transmission??? If this is the 87 IROC in your sig, then it is a 700R4 and the nonshifting is a mechanical problem. Either a broken shifter cable or broken transmission.
Oh, and your engine and engine bay are very dirty. All of that dirt will make the engine hold heat.
Old 08-09-2008, 10:19 PM
Dyno247365's Avatar
It can't be. I replaced the transmission with a rebuilt one and I got the same symptoms afterward.
So maybe it's ALL the vacuum leak's fault? How do I go about fixing this?
Old 08-10-2008, 01:42 AM
Vacuum leak won't affect the transmission. The shift cable for the 700R4 can be broken internally and unless you know what to lok for you'd never notice it.
To find the vacuum leak...listen and follow your ears. Then when when you have it narrowed down to an area, carefully spray carb cleaner (with the straw) to the area you think it may be. When the idle of the engine changes abruptly, you've found the leak.
Old 08-14-2008, 04:18 PM
Dyno247365's Avatar
I found a whistling noise, it goes on and off and sounds like it's coming from a vacuum hose. My question is should I replace all the vacuum hoses since they're old? Do I not need a new catalytic converter if this is the main problem?
Also I was revving it up to 3k today and the rpms were dying when I had my foot on the accelerator.
Old 08-15-2008, 01:23 AM
If in doubt, yes, change all of the vacuum hoses (there aren't that many).
To check the cat converter, get the engine hot (drive it ariund the block a couple times) then park it somewhere fairly dark and look under the car atthe converter, if it is glowing, it is plugged and needs to be replaced.
