Old 08-09-2008, 10:38 AM
rickisrad rickisrad is offline
Poly Mounts install
Well I purchased the offset poly dog bone mounts from ZZP and I am having issues with the install. First the 15mm OE bolts would not fit in the new mounts, so I purchased a set of 14mm grade 8 bolts from a hardware store and installed them. The new mounts have a lot of slop. I sent pics to ZZP and they said that they looked like they were installed wrong. If they are wrong I do not know what would be right. here are some pics. I installed the Power log, self made cold air intake, ZZP 1.0 pcm, 180 degree thermostat, and fabricated a custom 2.5" exhaust with 40 series flowmaster mufflers, yet I can not install a engine mount.... any help will be appreciated.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 08-09-2008, 05:44 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Poly Mounts install
Originally Posted by rickisrad
The new mounts have a lot of slop.....
Is your ride lowerd at all?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-09-2008, 05:47 PM
no it is not lowered. The upper dog bone mounts as you can see in the pic has a big gap, that causes it to move and knock when accelerating.
Old 08-09-2008, 06:46 PM
tblake's Avatar
In God We Trust
Oh ok, I understand now. I would contact ZZP and have them make it good. Or at least have them send you install instructions, and once you get them, email them back and tell them thats exactly how you put them in.
Old 08-09-2008, 08:00 PM
yeah I sent them pics already, and he said that they looked like they were in wrong. I just sent them some better pics. Like I said, I can not see how they are wrong. The tabs are right where they should go. I knew there was going to be a problem when the stock bolts would not fit in the new mounts. I cut out the old ones so I had no choice but to install the poly mounts. Hopefully they can make it right.
Old 08-09-2008, 08:11 PM
tblake's Avatar
In God We Trust
cut the old ones out huh? Damn!
Old 08-09-2008, 08:39 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The ZZP poly mounts are garbage. Wait 'til they start squeaking.
How much of the spacer the bolt goes through is showing on each end? Can't tell by the pics.
Timeslip 08/12/06
AF Community Guidelines
Old 08-10-2008, 11:15 AM
Yeah, I cut the old ones. That is what their link to the directions said to do. I can get another OE set really cheap If I have to though.
The spacer bolts are flush with the poly mounts..... So I spent 60 bucks for Garbage, that sucks. What brand should I go with for these mounts and any other mounts or bushings ? Do you think they will exchange the mounts for something else, anybody know their policies?
Old 08-10-2008, 11:21 AM
tblake's Avatar
In God We Trust
I think you can return to ZZP but returns are subject to a restocking fee.
Old 08-14-2008, 07:20 PM
What mounts do you guys use? I want to get another but I am not sure who has the best mounts.
Old 08-14-2008, 10:00 PM
tblake's Avatar
In God We Trust
Have you tried the ZZP "free mod" stock engine mount stiffening?
Old 08-15-2008, 06:48 AM
I am not sure what that is? before I bought the ZZP poly mounts I turned the stock mounts if that is what you are referring to. my old stock mounts are not in great condition after prying them out for the new ones.
