02 grand prix rear spring to tire clearance
does anyone no how much clearance you should have between the rear tires and the bottom of the spring housing. i'm getting a rubbing or scraping noise when i turn right with the car . i think the top of the tire might be hitting the spring housing on the right side .i'm wondering if its time for strut and spring replacement. car has 88,000 miles . thanks for any input
Re: 02 grand prix rear spring to tire clearance
The housing is stationary and is mounted to the hub, so there will be no issues there. The springs will effect ride height. If your fender clearance is minimal the you may get some rubbing there. Also check your rear sway bar, bushings and links. What you could do is use a tape measure and measure from the ground to your fender. this will get you the ride height. compare it to the other side(in the same exact location) and see if they are even.
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
