i need some help,i want to put a vtec controler into my prelude and would like to know some feedback from anyone that has one.what type of power curves will you see,and what benifits will i see from addin it?
you can lower the vtec crossover point which will flatten the power curve. it can give you more power at lower rpms. a vafc will allow you to tune the air/fuel mixture to the optimal ratio for your car. a lot of people like the fact that when you're able to lower the crossover point, you can stay within the VTEC range as you shift gears. at the stock setting at 5200rpms, a lot of times when you shift, you'll fall out of the VTEC range, where the least amount of power is. with the vtec controller, you can lower the point and prevent that.
on the other hand if you're a speed demon and just cruisin at the highway at 100mph for whatever reason and want to save on gas. you can also increase the crossover point so you're not in the high cam setting the whole time. |
thanks bro you just gave me all i needed to know:smoker2:
