Old 08-08-2008, 04:43 PM
b18a1civicef b18a1civicef is offline
running rich
my car is runnign rich how can i fix it i just put a new tps in it and it still runs rich it is a b18a1 so help please if you know how to fix it
Old 08-08-2008, 05:15 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: running rich
Try the O2 Sensor, thats usually the cause of it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-09-2008, 07:10 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: running rich
Yep, O2 or MAP... MAP's usually don't go on Honda's... only ever heard of one bad one... out of thousands... but, I suppose it's possible.
Check to make sure your ECU is the right one for the engine too.
Old 08-10-2008, 12:59 AM
Re: running rich
pr4 is the one i got
Old 08-10-2008, 12:43 PM
Re: running rich
Thinking about it... when you put the new TPS on, did you go through the adjustment procedure? or did you just screw the new one back in like the old one was?
The reason I ask, is that if your TPS isn't giving the right throttle angle to the ECU, the ECU may add more or less fuel than you need, depending on which way it's off...
This might cause a rich condition if your TPS is reporting, say, 50% throttle when you're actually only at 41%... ya know?
If you need the proper adjustment tut, I'll find it for you, just say something.
Old 08-11-2008, 01:38 AM
2002corolla 2002corolla is offline
Re: running rich
yeah double check the adjustment...if you haven't done so. then my next guess is the O2. they go bad as they age and if you have had a blown headgasket and got coolant on it that will coat it and make it not very accurate.
