Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-08-2008, 04:18 PM
navyboy85 navyboy85 is offline
Tuning with apexi 2
Well i have it all hooked up and adjusted the low throttle points but when it comes to high throttle i just cant get it to run any better then before it was on the car i have low set to 69% and high starts at 70% throttle i dont have a egt gage or wide band 02 sensor only a narrow band i was thinking about doing the blue wire mod so i can see the volts and try it that way what do u guys think or any advice.
MHI Evo 3 16g (Ported + 34mm flapper),GT Manifold (Ported),GT 2G install kit,190lph Fuel Pump,Denso 550cc Fuel Injectors ,Injen Intake,K&N Filter,HKS SSQV BOV,SBR 2.5" S.S. with Dump O2 Housing (Ported),Full 5Zigen Exhaust,3in" Downpipe, short throw shifter, apexi 2 afc, big front mount intercooler. 12 psi boost.
Old 08-08-2008, 04:48 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Tuning with apexi 2
Wait your lo is set to 69% and hi to 70%?? So the only time the SAFC adjusts fuel for lo-throttle is exactly when you're at 69% throttle.
Lo should be around 20% throttle, high around 60-70%. Then from 20-69%, the car is reading the lo-throttle settings, and 70 and up it reads the hi.
Use periods please. And then buy a logger at minimal and a WB.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-09-2008, 11:40 AM
Well i changed it to 30 low and 80 high and it runs alot better. Now i just need to get the percent it changes down but running alot better.
