Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-08-2008, 03:21 PM
chenyi chenyi is offline
Anyone know where is the lock-up solenoid on 98 Jetta?
My 98 Jetta Wolfsburg engine stalls while comes to a stop. And it shows a code "04A8", which I found out is the "Torque Convertor Lock-up Clutch failure".
I want to try to disable the lock-up clutch by disconnect the solenoid, but I don't know where does it locate and can not find the wires for the solenoid. Could anyone please help?
Thanks a lot!
Old 08-10-2008, 09:54 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Anyone know where is the lock-up solenoid on 98 Jetta?
if you unplug the solenoid the car will not move.
Its in the valve body you need to remove the pan and filter to get to it.
Old 08-11-2008, 09:36 AM
Thank you veedubmechanic!
But I thought the lock-up clutch should only work on 4th gear, on lower gears it's not working anyway... Maybe I was wrong.
