Old 08-07-2008, 06:52 PM
Zuki Zuki is offline
A/C vacuum lines
Hi, I just bought a 02 S10 crew cab with the 4.3 , when the a/c is on going up a hill the airflow shuts off, I know it's probably a vacuum line cracked. Can anyone tell me where it starts in the engine compartment and ends inside?? Thanks for any help.
Old 08-07-2008, 06:57 PM
j cAT j cAT is offline
Re: A/C vacuum lines
locate the vacuum ball....you should also check all the vacuum lines as this will affect your perfomance/mpg.... this is the usual cause of this issue vac line ...vacuum gauge will point out the problem quickly
