Old 08-07-2008, 10:51 AM
luchjeg6 luchjeg6 is offline
Avoiding dust
Why, when I spray a body everytime small dust parts land on the paint???
How can I avoid this. I have dust both inside and outside my house!
Second thing: After painting a body I want to clearcoat it and so I wash it before spraying clear colour... After washing some round parts of dry water are on the body... how can I clean them out without dirtying the body with dust?
Old 08-07-2008, 10:55 AM
jano11 jano11 is offline
Re: Avoiding dust
Buy or build a painting booth.
Old 08-07-2008, 11:16 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Avoiding dust
A spraybooth will help. But you should understand that it is not the ventilation and filtration devices in a spraybooth that control dust. Contamination control is up to you cleaning your booth before painting. If you do not clean it, a paint booth becomes very dirty very quickly. All the paint that you spray that does contact the model dries and becomes dust to contaminate the next body that you paint. So each time you paint a body, the booth must be made completely clean- like you are getting ready for surgery. Good booth ventilation means that when you spray, the booth does not collect and concentrate the vapors in the box where your model and face are. But dust control is really about making your painting area clean.
PHOTOBUCKET SUCKS
Old 08-07-2008, 11:21 AM
godfather23's Avatar
godfather23 godfather23 is offline
Re: Avoiding dust
I have made a very good experience spraying outside and then rushing the sprayed body immediately into the microwave. Even very wet coats donīt collect dust there...You just need to be fast. I donīt live in the desert, though.
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 08-07-2008, 11:57 AM
rockinanko's Avatar
rockinanko rockinanko is offline
Re: Avoiding dust
I can tell you how i control dust (still not 100% dust free) but i leave it up to you to decide if it's workable for you...
i do my wet coats....in the toilet!
yes, toilet with the door & window closed & the floor filled with water!
i placed the body inside & start flooding the floor with water, then i go out & prepared my paint...after a while (i assume dust has more or less settled on the watered floor) i come back & start doing the wets coat...one layer then go out close the door & come back @10mins repeatedly for 3 times...
that's how i minimise dust buildup.
I can feel the adredalin,
the same adredalin of what it's like...
to be a classic ferrari coachbuilder.
Old 08-07-2008, 12:39 PM
MPWR's Avatar
Re: Avoiding dust
Novel approaches.
There is nothing special, or particularly clean about the inside of a microwave. Like an oven, stovetop, food processor, paintbooth, or any other appliance in regular use, they must be made to be clean. They do not make or keep themselves clean. An easier solution would be a sealable plastic food container.
But if your using fast drying paint (like aqueous acrylic or lacquer) it's really only dust present while you're painting that you need to worry about. Anything that settles on the body after the paint is applied can easily be brushed away after with a clean cloth, lens cleaning brush, or some very fine sandpaper.
PHOTOBUCKET SUCKS
Old 08-07-2008, 01:18 PM
Re: Avoiding dust
MPWR: "But if your using fast drying paint (like aqueous acrylic or lacquer) it's really only dust present while you're painting that you need to worry about. Anything that settles on the body after the paint is applied can easily be brushed away after with a clean cloth, lens cleaning brush, or some very fine sandpaper."
Exactly, the problem is the dust that it's present while i'm painting the problem!!
Old 08-07-2008, 01:21 PM
KevHw's Avatar
KevHw KevHw is offline
Re: Avoiding dust
When it comes to dust, I always consider airflow around the model/painting area. Dust mostly falls and so I always try to make sure that there is a good flow of air above and around the model so that no dust falls onto it. The air being blown over obviously also needs to be dust free, so I try to filter it.
Using a "booth" or as I use the poor-man's booth...a box...simply reduces the size of the "room" you're spraying in, so making it much, much easier to control the quantity and movement of any dust present. When using my box or "booth", I mainly concentrate on the exhaust system and thus try and work along the same principles of a vacuum chamber (like they use for making computer processors).
I never wash before applying clear coat...more especially so if there are decals .
Old 08-07-2008, 03:14 PM
Re: Avoiding dust
Originally Posted by MPWR
Novel approaches.
Now, come on. You are right from an objective point of view but you have to admit that this one of the more cleaner and dustfree places in a home. And its regular use - which is rather clean - adds to this.
So please everybody, my advice was not an objective one so I shall edit it: I personally have achieved good results using a clean microwave to dry my paint jobs. That is I must admit more sincere and truthful.
End of novel.
Robert
Current Projects:
Old 08-07-2008, 03:24 PM
klutz_100's Avatar
Re: Avoiding dust
I recommend you get a dehydrator.
I fought it for a couple for years because I thought it was a bit overkill. How wrong I was!
It will not only provide you with a (relatively) dust free environment with a positive airflow/preassure but it also dries your paint out very quickly which significantly reduces the risk of any dust sticking to your wet paint.
Also remember that any small dust/hairs/fibers that get into the paint during the painting stage can usually be easily sanded out and the area polished back up to a shine. After all, I don't suppose you are talking about dust at the levels of ..... (or are you? )
Honestly, you wouldn't believe the dust lying around in my workroom in the cellar and I don't really have an issue since I started using the dehydrator.
My
Old 08-07-2008, 03:56 PM
BVC500 BVC500 is offline
Re: Avoiding dust
I was lucky when I used to paint on the balcony of my apartment in Miami and I rarely ever got a speck of dust in my paint. It was a north facing balcony with walls on three sides. Oh, how I miss it! Good preparation, no doubt, but also good air quality and the right conditions.
Old 08-07-2008, 04:18 PM
MPWR's Avatar
Re: Avoiding dust
Maybe your microwave is cleaner than mine. I might guess that the radiation keeps things fairly bacteriologically inert in there, but certainly not clean. Every time a reheating curry boils a bit in mine, it splatters bits of debris here and there. Also because a microwave is a somewhat heavy five sided opaque box, it can be rather difficult to asses how clean it really is/isn't.
But then on the other hand if it works for you, there's no real reason to change it.
A dehydrator may help with outgassing paint. But as the real concern is dust during the painting process instead of dust after, I'm not sure how much it would help with contamination control. Honestly when I've just applied a coat of paint and it is still soft, the very last thing I want to do is risk moving it anywhere. It's just too easy to bump it into something and mar/ding/damage the paint- and that for me is alot more work to fix then brushing off some dust. I've learned from experience that an hour or so sitting unmoved and undisturbed in the booth with me not around to bump it/admire it/mess with it is by far safest. If I leave it alone, it does not get dropped on the floor, crushed by a dehydrator lid, or melted with a cup of tea.
PHOTOBUCKET SUCKS
Old 08-07-2008, 05:49 PM
racer917's Avatar
racer917 racer917 is offline
Re: Avoiding dust
I always spray outside and then hang up the parts, and yes even car bodies, to dry under my porch roof and I never get dust on them.
Old 08-07-2008, 07:41 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Avoiding dust
unless you have one of them swanky ovens that has a self cleaning mode where it basically goes mini-supernova inside to burn up any cooking gunk left inside.
AF's Guidelines
Read them.
Old 08-07-2008, 07:53 PM
nakadds nakadds is offline
Re: Avoiding dust
You could get an air purifier/cleaner. I turn it on 30min before painting. Helps to cut down the amount of dust particles floating around.
